How to Import files from CASSY lab software
How to Import files from CASSY lab software. I shall be obliged and thankfull for an early help.
(5,424 Views)
Can you give us more information?
What is CASSY software?  What kind of information is stored in the files?
(5,417 Views)
CASSY is a computer assisted software system. It is used to collect results of several experiments of physics and chemistry on the computer screen. A device called CASSY sensor is cascaded with the apparatus and then through a usb port it is connected to computer. The software has alredy been installed on the computer , so all the readings can be taken on computer and can be saved.
I wish that by using labview software i shoud be able to show my entire setup apparatus on computer screen along with that CASSY sensor and can operate it on computer instead of doing experimentr manually.................................. Or if you can help be to generate the recorded results ( readings and graphs) of CASSY on labview that will also be ok.
Kindly reply soon . Thanks.
(5,401 Views)
Did you try searching?  There are LabVIEW drivers available for it already (bottom of the page):  http://www.leybold-didactic.de/data_e/software/index.html?cassy-s.html
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(5,396 Views)
Hello Sir
First of all , i want to say thanks to you for providing me the guidline. With your help i have arranged the drivers of CASSY LAB in labview but I am unable to understand how to use them. I want your help in this regard. Can you please send me a solved example relating to the experiment “TO VERIFY COULOMBS LAW BY USING CASSY LAB” or another experiment is "MEASURING FORCE IN MAGNETIC FIELD OF ELECTROMAGNET WITH CASSY LAB".
These are experiments given by LD didactic company who is the supplier of CASSY LAB. I have already performed these experiments so their examples can  help me in understanding.
I SHALL BE THANKFULL TO YOU.
(5,377 Views)
It you look at the help file that is part of the driver, it states. "Please email your questions and remarks to cassy@ld-didactic.de". All the other information on this page appears to be in german, but it might be worth a shot to send them an email. It looks like the driver just calls into a DLL they wrote. I think contacting the CASSY developers is probably going to be the best use of your time.
I hope this helps!
Verne D. // Software R&D // National Instruments
(5,362 Views)
