How to Install DAQMS and NIMAX in Ubuntu?
I am pretty new to Labview, and installed it in my Ubuntu 20.04 using this link.
https://www.ni.com/en-sg/support/downloads/software-products/download.labview.html#443274
Then I also installed the DAQMS driver from https://www.ni.com/en-sg/support/downloads/drivers/download.ni-daqmx.html#428058
But it seems NIMAX is not working for which my online instructor says it is necessary to have DAQMS. How do I verify my DAQMS installation and how to install it properly in Labview?
(2,139 Views)
Hello, barmanroys. What version of LabVIEW and DAQmx did you install? Versions must be the same․ Can you check the versions and reply to me?
(2,106 Views)
Was your problem solved?
(2,091 Views)
