How to Measure Voltage Using NI 6001 and Calibrate Using LabVIEW
Hello GerdW,
Can you send a sample code for that tare problem for reference.
Message 11 of 29
(2,039 Views)
Hi Tanmay,
see message #7
Message 12 of 29
(2,032 Views)
Hello GerdW,
I tried Making the tare/zeroing code but I'm stuck. Please help me I'm new to LabVIEW.
I'm attaching the code in 2018 version
Message 13 of 29
(1,995 Views)
Hi Tanmay,
  • replace BundleByName with a plain Bundle function
  • replace the graph with a chart
  • set the datatype of that "5" constant to DBL to avoid the coercion dot
  • connect the "Numeric" indicator to the output of the FromDDT ExpressVI
(As has been shown in message #7! Why didn't you use the supplied snippet?)
Message 14 of 29
(1,990 Views)
Hello GerdW,
I made the code and I'm getting a Good output with a difference of 0.02 to 0.05.
Is there any way to remove those differences too ?
also I'm attaching the code for reference.
Message 15 of 29
(1,958 Views)
Hi Tanmai,
Question: what is the measurement range and what is the expected noise level?
(When the offset always is positive then there is a systematical error, which can be corrected. When the offset fluctuates around zero then it's a random error (aka "just noise")…)
You may apply more averaging and you may do better taring (aka tare as often as you want to), but I don't think that will help without introducing other problems!
Message 16 of 29
(1,971 Views)
Hey GerdW,
can you guide to how to add write to measurement and take reding for every 15 minutes without disrupting Tare/zeroing button.
I've added one but, for after clicking tare button it tares after 15mins.
Message 17 of 29
(1,945 Views)
Hi Tanmay,
I don't see anything in your latest VI related to "15 minutes"…
What I see:
  • There still is an additional wait function next to the DAQAssistent: Let DAQmx do the loop timing on its own!
  • The DAQAssistent is set to read 100 samples at 1kS/s: this will take about 100ms. Why do you wait for 500ms?
  • The DAQAssitent is set to "N Samples" mode: why not use "Continuous mode" when you read samples continuously?
  • Why use DAQAssistent at all, when all example VIs coming with LabVIEW explain the usage of "normal" DAQmx functions? (Read this!)
  • Why not save measurement data once each 15mins*60s/mins*10iterations/s? Then you will get your data and will not "disrupt" the taring…
Message 18 of 29
(1,939 Views)
Hello GerdW,
sorry for Inconvenience, actually I added a flat sequence for write for measurement but it failed.
so, you're recommending me to use DAQmx instead of DAQ assistant.
I need to understand how to measure values for 15mins in DAQmx without hampering the tare/zeroing button.
Also, Thankyou for your suggestion even I was thinking of using DAQmx
Please help me with an example or hints
Message 19 of 29
(1,930 Views)
Hi Tanmay,
Think about it: measuring once for 15mins is the same as measuring 9000 times for 100ms!
(You already have a loop to measure for 100ms: you just need to iterate 9000 times…)
Message 20 of 29
(1,920 Views)
