How to Plot 16 Signals From a Single 8 Channel 2 Sources Data File?
Matrix A is a time + 8 channels from a single assyncronos data source; MSC is a XY Chart. This works fine until now that data records changed to 2 assyncronos sources. Format now is: where the data came from (0,1) + time + 8 channels data.
Rgds,
rgds,
Haroldo - Brasil
LV 7.0
Message 1 of 13
(5,955 Views)
Your description doesn't make much sense to me.  And if you want to post a screenshot, you must first attach an image file to your message.  The image you embedded in your message is located on your hard drive, and for obvious reasons, we don't have access to that.
A VI that has some real data saved in the controls as the defaults would be even better to look at.
Message Edited by Ravens Fan on 04-14-2009 03:21 PM
Message 2 of 13
(5,951 Views)
HiHaroldo,
when the file format changes you have to change the reading routine too...
If you would give more information we could provide better help!
Message 3 of 13
(5,950 Views)
Sorry but I haven't seen any attachment button.Smiley Sad
rgds,
Haroldo - Brasil
LV 7.0
Message 4 of 13
(5,945 Views)
A is not a matrix, but a 2-D array.
Please post your VI and a data file so we can try running it.  I am still unclear as to how the image you posted relates to your question.
Message Edited by Ravens Fan on 04-14-2009 03:37 PM
Message 5 of 13
(5,942 Views)
So even without seeing an attachment button, you still managed to a attach a file.Smiley Very Happy
Message Edited by Dennis Knutson on 04-14-2009 01:36 PM
Message 6 of 13
(5,940 Views)
I am from the time where we call 1-D of vector and 2-D of matrix. If you push the 'tree icon' you can add an image, too. Sorry, 'veterans'.Smiley Surprised
Anyway, bellow you find code and files.
rgds,
Haroldo - Brasil
LV 7.0
Message 7 of 13
(5,928 Views)
I can't run your VI because the Read spreadsheet file with headers is missing.  I think it is an ancient VI that NI no longer ships with LV.
Looking at your 2 Source file, it looks like you have a new column at the beginning that has a 0 or a 1 and you want to break these out?
I think what you will need to do is read in the text file line by line, and depending on whether that first column is a 0 or 1, build the new line of data into 2 different 2-D arrays.  Once you have the 2 different 2-D arrays, then you can use the code similar to what you already have to break it up into X and Y data for graphing.
(In LabVIEW, a matrix is a different structure than an array.  It is located in the math palette for linear algebra.  It is of course similar to an array, but is a special structure.)
Message 8 of 13
(5,903 Views)
Original 8 Channels ed.txt is a file where a line is a record of time followed by 8 data values. They
are TAB separated. Data are sampled assyncronously taking from 130ms to 160ms to get a
record. It is plain text TAB separeted and the first line is the name of the channel so Excel can
plot then (you can have an "idea" how it looks like because is not sync.).
We can use Test Read File 8 Channel.vi to plot a file like the one above. It uses XY chart instead
of graph to show data. Read From Spreeadsheet File.vi is set to transpose rows and columns so
 the 2D array (A) living it are split and combined as 1D pairs keeping the fisrt row (now "time") ), or
X, for the XY chart vi.
On the new situation we have one more source of data, that also fills the file (2 Source 8 Channel ed.txt) with a record from 65ms
to 90ms. Thus, in fact, the file now have two sets of 8 channels or 16 channels of data.
The trouble here is to know if we can keep using a single XY chart to show 2 sets of 8 XY pairs of
different length but 16 channels. We was wondering if it will be necessary to convert then to a
waveform data type first.
PS. The data files bellow came from a simulator and the time values are smooth. We edited then
removing header to keep what is relevant to the problem.
rgds,
Haroldo - Brasil
LV 7.0
Message 9 of 13
(5,885 Views)
Hi Haroldo
Like Ravens Fan says, you can use the first column to split the data into two 2D arrays, then build your XY plots from them. Take a look at the attached vi.
Ian
Message 10 of 13
(5,872 Views)
