How to Program Xilinix Artix-7 FPGA on my DUT using LabVIEW
Thank you cbutcher, GerdW & rolfk for your support.
Message 11 of 14
(1,232 Views)
hi, Can you post your Vi's here? I have the similar requirement and looking for the command to use with system exec in labVIEW.
Diana
Message 12 of 14
(1,121 Views)
My Requirement is to download the Truth table into the FPGA automatically(Its not NI FPGA, it is external Vendor FPGA). Currently i am using Xilinx parallel cable (hardware) and Xilinx ISE 6 (Software application) for programming Manually. Is there a way to automate it using the LabVIEW?
Message 13 of 14
(1,133 Views)
What have you tried so far? Have you read this thread carefully and tried to understand what solution was proposed, which the OP eventually implemented successfully?
His last post was almost 2 years ago, so you have to account for the possibility that he no longer uses the email he registered with, may not be working with LabVIEW anymore, may have no time to come here to respond or unable or unwilling to share any of his work.
This means there is a very strong chance you will have to do the work yourself, pull up your sleeves and get your hands dirty and tired with some real programming work of your own.
So start reading and when you get problems about something that has not been mentioned in this thread already or you don’t understand something specific, then show us what you have done so far and ask. We are willing to help but not to do your work for you. If you want that you need to consider hiring someone.
Rolf Kalbermatter  My Blog
Message 14 of 14
(1,101 Views)
