How to Programmatically Hide a file (*.ini file)...?
Hi am working with an application in that i want to show only some specified files to the user and the remaining files i have to hide it... Is there any way to hide a file saved in the Computer Hard disc?....
(4,798 Views)
Hi Anand,
you don't say how you show folder contents to the user.
Using the standard file dialog you could use the pattern input to hide files.
Using the ListFolder function with a listbox (or table or whatever) you can apply any filtering on your own...
Is there a special meaning in the dollar and minus chars of your signature?
(4,787 Views)
If a user is determined, any file can be found. Can you tell us what you mean by "hidden"?.
You can set the file attribute of an ini file to "hidden" as part of the installer configuration. This way it won't show unless the users has the computer set to show hidden files.
(4,779 Views)
You can use the command ATTRIB to set the attributes of file(s).
Ton
My LabVIEW Ideas
(4,761 Views)
Ok GredW and altenbach i'll explain what i do...
I am saving some configuration information in two files say A and B (Both are different configurations ) and i'll be having the information about one file ( File B) into the file A. So if I select File A  automatically all the configurations will be loaded (Including the info written in the File B) .. This is my concept and i want to display only the File A to the user in a browser window provided both the files (A and B) in the same folder.
No GredW i just wanted to make some design for my signature... But dont know how to do it..Smiley Sad
(4,757 Views)
