How to Properly Destroy Quicktime ActiveX Object?
Does anyone have experience with Quicktime ActiveX objects?  I'm having an issue about destroying/unloading the objects.  When my compiled executable is closed (either programtically through 'Quit Labview' or by selecting 'File-->Exit'), Windows 7 detects a crash and displays:
So I'm guessing that Quicktime is the culprit because of the 'Fault Module Name'.
When I shutdown the Quicktime portion of the program (a subvi that gets called several different times), I perform:
  1. QTOLibrary.IQTMovie.Stop
  2. QTOLibrary.IQTMovie.Disconnect
  3. Set QTOControlLib.IQTControl.URL = [blank]
  4. QTOControlLib.IQTControl.QuickTimeTerminate
  5. Destroy QTOControlLib.IQTControl reference
  6. Destroy QTOLibrary.IQTMovie reference
  7. Destory QuickTime ActiveX container reference
Any other properties/methods/combinations/order I should try?  Thanks.
-Joe
(4,529 Views)
Hi Joe,
Quit LabVIEW shuts down LabVIEW, but does not affect other applications. You need to ensure that your ActiveX references are being closed properly, even if you are quitting LabVIEW.
A good way to ensure that your references are being closed even when you forcibly exit LabVIEW is to use an event structure. Add a new event to the event structure by right clicking on the default "Timeout" label at the top and selecting "Add Event Case...". Then, under the Event Source, "<Application>", select the event, "Application Instance Close". This event will only execute when you attempt to close your application. Add another "Close Reference" function to the block diagram and wire the reference out output of the Invoke node to the reference input of the Close Reference function. Does this fix your error?
Julianne K
Systems Engineer, Embedded Systems
Certified LabVIEW Architect, Certified LabVIEW Embedded Systems Developer
(4,517 Views)
I added this to the main VI:
Is that what you meant?  I still get the same error report.  I also checked that I close the individual ActiveX references properly.
(4,511 Views)
Hi Joe,
Can you give me some more information about what you program does? Also, after you receive this error, can you open Quicktime? Does it start normally or do you receive error messages? Thanks,
Julianne K
(4,502 Views)
Hi Joe,
Did you manage to solve your Quicktime ActiveX troubles??? I am having the same type of headaches ... any help/advices are appreciated 😉
Thanks a million.
Chris
(4,459 Views)
Hi Chris,
No, I never did find a fix for this.  So if you find anything out, please post to this thread.  Thanks.
-Joe
(4,454 Views)
I finally came back to this application and I believe I have it figured out.  As far as I can tell, the all 3 types of references can be destroyed or not destroyed without consequence.  The same applies to the 'Connect' and 'Disconnect' methods.
The crash occurs because of file handles still being open.  I was 'unloading' movies from the Quicktime control by wiring a null string to the FileName or URL property.  Quicktime doesn't handle this correctly and leaves the original file open.  So instead I wired a path to an actual image file (Quicktime does images too) that was all black.  Eveything seems fine now.
(4,424 Views)
