How to REGENERATE VALID GUI SubVI Reference
My Block Diagram is attached here:
-- I make sure that before I restart the VI, I abort the existing instance,
-- I then reCreate the GUI SubVI reference,
-- I can confirm that the GUI SubVI is infact a new reference (different ref number)
-- I then:
    (a) Assign values to Front Panel Controls
    (b) Open the front panel,
    (c) RUN the subVI.
The issue is this:
After this GUI SubVI has run for about three days in an owning VI SubPanel. I am no longer able to OPEN the VI independently because I get the VI Ref INVALID error.
Question:
Is there a way to generate a VALID VI reference of a LabVIEW VI window? When I run this LabVIEW code and find that the VI ref number changes as I reStart the VI, my question is how can I ensure that the new VI Ref is VALID.
Anthony
(1,943 Views)
Hi Anthony,
I see no error handling in your image.
I don't understand that FOR loop with sequence inside:
  • Why do you need to close an invalid refnum?
  • Why do you need to open the refnum twice when there is an invalid input?
How often do you need to open the VI refnum?
Do you close all refnums correctly?
How many other refnums do you need to handle?
Did the subVI run 3 days without closing/re-opening its reference?
I suspect there is a problem of "too many open refnums" that let's you run into the "not able to open any new refnum anymore" error…
(1,908 Views)
@Anthony_L wrote:
Question:
A static VI Reference would be a lot easier...
(1,878 Views)
Hello:
Thanks for suggestion:
How does one do that? And maintain it as valid RefNum throughout?
Thanks Again
Anthony
(1,874 Views)
Hi Anthony,
You create a static VI reference by placing the StaticVIReference on your block diagram and drop the VI onto it...
Because such a VI is (kind of) "embedded" inside the StaticVIReference it will be always valid!
(1,872 Views)
Hello Gerd:
Thank you for considering my question.
That FOR LOOP ensures that I am able to grab a valid reference to the VI and ABORT the VI. Before relaunching the VI.
When it runs for the first time, the feedback node sends an INVALID REFERENCE. So I need to grab a fresh reference to be able to Abort the VI BEFORE ReLaunching the VI.
The reLaunching of the VI is because the VI MUST be removed from a subPANEL CONTAINER and made to run as an independent window. .
In Those 3-Days that the VI stays running it is never opened or reOpened. Infact it is not even touched. The VI just acquires and plots points via a LV 2Style global and will keep scrolling.
However, once the Vi is accessed and command issued to relaunch as separate window, a VI Reference can no longer be acquired.
Anthony
(1,864 Views)
Thanks!
Let me try this.
Meanwhile if I am really running out of references, i need to address this as well.
Anthony
(1,860 Views)
