How to Read CI Period Using Sample Clock In PCI-6284?
I'm using Daq card pci 6284 and trying to read Counter Period using Sample Clock.
But during execution Error -200300 appears at Daq Start Task.vi.
How to correct the issue.
(3,078 Views)
Accepted by topic author Thiruveni
You'll need to use the "Implicit" version of DAQmx Timing rather than the "Sample Clock" version.
The idea is that the timing information is "implicit" in the signal being measured.  The timing intervals that define a period are defined by the signal itself, that's why counter period measurement can't use a "regular" sample clock.
-Kevin P
P.S.  Newer boards such as the X-series MIO *do* offer frequency measurement modes that involve constant-rate sampling.  I don't they offer similar constant-rate sampling for period measurement, maybe because freq measurement is much more common and the conversion to periods is trivial.
(3,056 Views)
