How to SET DAQ digital output in mid DAQ Acquisition in Labview
Please Help...
I must acquire a signal step response from a system.
I must guarantee to capture all of the response, so I want to start acquiring a sample, and then in mid sample acquisition SET a digital output to 1.
How could I do this?
I have only one DAQ acquisition board model PCI-622 with a CB 68LP adapter.
Please help...
Thx in Advance
(3,333 Views)
In order to help you, I need some more explanations.
First what is your board exactly? PCI 6220, 6221? Because I think 622 is a mistake, isn’t it?
Then, if I rephrase your problem: you want to acquire an analog signal (a step response). And, in the middle of the acquisition you want to put a 1 on a digital output.
So my questions:
1)      How much time will last the acquisition (actually the response of your system) approximately?
2)      How do you define “the middle of the acquisition”?
I am waiting for your answer.
Regards.
PS : We can also talk in french if you want.
Jean-Philippe C.
National Instruments France
(3,312 Views)
many thanks for your prompt reply...
Yes! Sorry for the mistake... Its a 6221 model...
1) The settling time for my signal will be around 100us;
2)Ok... I will define the problem better better...
-Lets say the whole process will take around 120us;
-At T=0us I want to start acquiring with maximum samplerate; 250Ks/sec==>1 sample every 4us;
-At T=10us I want to send the output signal to one the excite the system;
-The output must stay at one;
-At T=120us the data acquisition will stop;
-After (time is not important) the output can be but back to 0.
Hope this explains it better. Thanx for the help...
I speak a bit of french but sadly a bit rusty 🙂
Ricardo Greenfield
(3,290 Views)
Ricardo,
 It sounds like you could use pre and post triggering samples for this application. Are you using a digital trigger to stimulate your system? Maybe this tutorial could help.
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,280 Views)
