How to Select LabVIEW Flavour
I wanted to control RF Signal Generators, having GPIB interface, which gives their output to RF Antenna under test, Results from RF antenna are to be captured on serial interface.  As RF control signals  are to be applied and results are to be captured on serial there will be time-criticality on control and capture software modules. Which LabVIEW flavour will be suitable for such Measurement and control application.
I am confused with LabVIEW Full, Professional and LabVIEW RT, LabVIEW Embedded etc. Please guide me in selecting LabVIEW Flavour and also which OS/platform should be used (eLinux, Linux, Windows)
(4,078 Views)
We re using LabVIEW Professional Development System with Windows XP SP2.
- Partha ( CLD until Oct 2027 🙂 )
(4,070 Views)
Hi AmoIT,
have you tried to contact a local NI representative?
They are quite good on giving recommendations once they talked with you on your exact needs...
(4,069 Views)
Hello Partha,
Thanks for your prompt reply. Just wanted to know... are you also using LabVIEW Professional for RF control , measurement and analysis applications?
(4,050 Views)
Hello Gred,
Thanks for your valuable suggetion, I had thought abt this option, but i ignored it under assuption that the Local NI representative will be a Marketing only person...but as you had good Exp. i will aslo try to meet them. Thanks once again
(4,048 Views)
Hi AmolT,
If you re from India, try to call the toll free number 1800-425-7070, and get routed Abhishek Nag. He is one RF guy who helped us in the beginning of our project providing valuable suggestions.
Or, you can contact NI support team as GerdW had suggested in his post.
(4,037 Views)
