How to Set System Mappings For Veristand Using API
I am trying to make a VI that would map the system channels for me inside of a Veristand system definition file. I have quite a few mappings to make and many of the port names are repetitive, so this should be easy to implement. I have attached pictures of my attempt below. The front panel shows the results. The Get Sources and Get Destinations indicators show the one mapping that I made inside of Veristand itself.
I have used the Get Channels block in LabView to verify the path structure and you can see from the Get Sources and Get Destinations indicators that they are correct.
I am planning on throwing this in a for loop and incrementing the number to make all of my connections.
Thanks in advance,
Brent
(4,732 Views)
Accepted by topic author B2.718
I wrote up some very similar code and it seems to configure system mappings correctly for me as long as I have the system defnition file closed while running the VI.
(4,704 Views)
It does work properly. I had a space character at the end of some of my port names that I did not realize I had.
Another way to do this that is very nice is to create a tab delimited text file.
Source tab Destination
and then import into the system definition in the channels dialog box.
-B2718
(4,666 Views)
