04-18-2006 04:11 AM
04-18-2006 04:56 PM
04-21-2006 08:05 AM
04-21-2006 01:51 PM
04-24-2006 05:00 AM
04-24-2006 09:05 AM
@andress wrote:
i don't know what "copy of the historical database" do you mean!
04-24-2006 09:12 AM
After installing the runtime you should only have to reboot the computer in order to get the citadel service running. At the point, for citadel purposes, this machine will behave as though you had the DSC development system installed. The 8.0 runtime has no setup requirements...it should only need to be installed. Unlike previous versions, 8.0 requires you to build your application into an executable and the runtime should be invisible to you once you install it. If this is not the case, please post about it so it can be looked at.
If you have specific questions, please post them and I will either try and help you find the answers, get them posted, or answer them myself.
05-03-2006 04:47 AM
05-03-2006 08:18 AM
