How to Update the C# dll in LabView
Hi.,
 i created C# dll with "ADD"  Function. in that dll contains only that function. for that function i am passing two variables.
 "public int Add(int A, int B) "
in the Labview, i use the .NET constructor(Drag and drop the node and in the dialog box i browse the .net dll) and Invoke node to access the
method it's working fine..
Now the Problem, After build the dll i added some more function in the c# dll.
"public int Sub(int A, int B) "
In the labview i can't see the new method in the "Invoke Node". so in the ".NET Constructor" dialog box i browsed the same dll but i got the Message "The version of assembly you requested was automatically  promoted to a newer version by the .net runtime engine"
the newer version of the dll not updating. How to get the newly added function.
Please help to fix this problem
Message 1 of 11
(7,074 Views)
Have you tried to browse again your updated dll in the "Select a constructor.." dialog box?
Have you tried to call the new function of your dll in another .NET langage (C# for example)?
Gilles
Gilles K.
Electronic System Engineer, Renault F1
Message 2 of 11
(7,063 Views)
I tried in the labview but is't says the message "The version of assembly you requested was automatically  promoted to a newer version by the .net runtime engine"
i tried in the other c# project in the same dll it's working. i tried to decompile the dll and i see the code., the new function is there.
Message 3 of 11
(7,054 Views)
Message 4 of 11
(7,051 Views)
Try to delete the constructor, save the VI, add a new constructor and select your dll again.
It's a workaround proposed here : http://forums.ni.com/ni/board/message?board.id=170&thread.id=229618
Gilles K.
Message 5 of 11
(7,049 Views)
Yes. i tried that one. not working..
i closed the whole labview and create the new Vi  that time also the same problem.
Accidentally my system restarted after i created new VI and browse the dll it's working.... so i add again new function to the dll and checked same issue is coming.... i am getting same Message...
i am not able to get what is the mistake!!!!
Message 6 of 11
(7,035 Views)
Do you tried to increase the version number of your assembly (LVCall 1.0.0.1 for example)?
Gilles K.
Message 7 of 11
(7,017 Views)
yes. i tried that one also.
every time building the C# dll i am increasing the Version no... but no luck.....
Message 8 of 11
(7,009 Views)
Anyone ever figure this out?
I've got Labview code that is calling a DLL and that DLL I update frequently.  Very slow and frustrating process.
Message 9 of 11
(6,016 Views)
Hi I has the same problem with my C# DLL.
(I'm lucky I don't have to update it frequently).
If I remember correctly in order to use the new defined functions I had to
1) Remove constructor nodes and save the VI
2) Exit labview
3) Restart Labview and replace a new constructor node.
Marco
Message 10 of 11
(5,999 Views)
