How to Use TFTP LabVIEW?
Hi All,
I want to open TFTP functions from LabVIEW.
Is there any in built  functions in LabVIEW for that?
How can I transfer a file using TFTP from LabVIEW?
Please suggest.
Can usend some examples.
SajK
(5,180 Views)
You can build up your dos command string and then use system exec.vi.
I used an ip address for the host. If preferred path controls could be replaced by string controls.
This should get you started. The VI is 8.0 and I tested the put and get commands.
David
(5,169 Views)
