How to Use two E-Series cards in Labview
I have two 6024E multifunction cards. I have to program a dual station machine - that work independently to each other. I am trying to generate 0-10 volts on the two cards independently at the same time, but when I try this, one of the cards generates the 0-10 ramp and only when this is complete the second ramp starts. I know that I could not accomplish the above with one card, but with two it should work ??
(2,413 Views)
The two cards should work independently from each other. It may be something in the way your program talks to the cards. Can you post a simplified VI showing how your program works? It is difficult to diagnose the problem without knowing how you are trying to do things. Also mention the version of LabVIEW and platform.
Lynn
(2,413 Views)
Lynn is correct, two cards should be able to work independently from each other. Perhaps you could describe in more detail what you are trying to do.
Sal
(2,413 Views)
