How to WRITE/SAVE picture data into BMP format
I can't figure out how to simply write the picturedata I created to a BMP, or whatever format using the picture format tools. It's easy to read a file and make a picture from the flat data.. However I've been trying all kinds of mindwarps to get the bloody picture to write back into a BMP file after making changes to the picture. How can you convert the picture data into flattened data again? The manual is extremely vague on this matter.
(3,213 Views)
Hi Swami,
to get the 'bloody' thing done you have to use the invoke node (method) GetImage of the picture indicator that returns the picture data.
I enclose a simple vi that lets you load a BMP file into a picture and save it back in a BMP file.
By default I set the image depth to 24.
Good luck,
Alberto
(3,213 Views)
Thanks for the perfect response Alberto,.. I'd never had gotten to this solution myself. Well maybe in 1 year or so 😉
Swami
(3,213 Views)
Don't give a damn.
I bumped into it almost accidentaly myself.
As you said documentation is lacking!
Alberto
(3,213 Views)
