How to ablate the empty line of a string?
Hi everyone!
I am creating a string control in LabVIEW 7.0.
I would like to know how to ablate the empty line of a string?
For example, I have three string input controls, they are grouped together in every other line.
The output indicator will show:
String1 data
String2 data
String3 data
However, when one of the string controls is empty, the indicator show as follow:(e.g. String2 is nothing)
String1 data
String3 data
My ideal string output is that all data are reformed the order automatically as follow:
String1 data
String3 data
What should I do???
(2,993 Views)
See attached VI using LV 7.1.
Hope that helps. 🙂
Neil
Message Edited by NeilR on 05-18-2005 06:21 AM
(2,981 Views)
Hi NeilR!
Thank you for your reply!
I can't open your solution file, because I am using the LabVIEW 7.0
Would you plz help me again with a 7.0 file or a jpg file?
Thank you very much.
(2,961 Views)
Try this 🙂
(2,954 Views)
Hi NeilR!
Your solution is excellent!
How about if I do not use the "For Loop" but a "While Loop"?
How to improve it into a While Loop type?
Thank you very much!
(2,933 Views)
