How to abort subvi in subpanel?
Hi is there anyone who knows how to abort and close the sub-vi inside the subpanel
while the main.vi  or sub-panel is still running and able to open the another sub-vi again?
(4,869 Views)
Hi
I assume you have a sub-vi, which has a while-loop. Just stop this loop and close the front panel using an invoke node. If you insert the sub-vi into the subpanel, check if the front panel is open. If so, just insert and run it, otherwise open it first.
Hope this helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(4,860 Views)
You should be able to insert a vi, run the vi with an invoke runVi node (use wait for completion = FALSE so the vi runs in its own thread) and if you need to stop the vi, call "abortVi" with the reference to the sub-panel's vi, this will stop the vi, then you can programmatically close it and insert a new vi.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(4,850 Views)
A better way to stop a vi then abort is to allow for some communication protocol like a custom event or a message queue to signal to shutdown this will allow for a safe abort  of the vi in the sub-panel but requires more planning so think if it is worth the work.
Paul.
Paul Falkenstein
(4,847 Views)
It always depends on the situation, how you implement communication. But it's always better to know what's going on than just abort a vi.
Using LV8.0
(4,848 Views)
Hi. Here are 2 attached. They are simple. First I created one that increments the number throught out the loop inside the subpanel.till it is stopped by button outside the subpanel. . However, there are two problems that do not work right. One, the loop stops at 2 or 3 even the button is not pressed outside sunpanel. Maybe due to notifier communications. Two, vi inside the subpanel cannot be stopped and removed.
So how do I do about it. There are no good examples shipped with LV.
Clement
(4,777 Views)
Hi,  Becktho and Falkpl,
I manage to solve the problem All I have to do is create a another loop for send notification. So now it works.
Most important, is that the I must create send notification and wait for notification in each loop.
Clement
(4,746 Views)
