How to access CFP1808 via cfp2020
I have an old hardware for a client ( LV 7.1 RT and CFP2020). We have add a CFP1808.
 I have access from MAX, everything it's OK, but i don't have access to cfp2020 embedded software
If an person a have a solution or better a VI, it's cool.
thanks,
Jokary64
(3,060 Views)
Did you follow all the instructions given in section 8 and 9 of the Getting started guide?
http://www.ni.com/pdf/manuals/373334d.pdf
Could you be more specific when you say that you can't access to the embedded software? What do you see in NI-MAX? How do you try to access the software and what happens?
Pierre-Emmanuel BELLES
Certified LabVIEW Developper
Certified TestStand Architect
(3,023 Views)
I want access cfp 1808 from my cfp2020 in LV RT 7.1.
I communicate in Ethernet, all is OK. I see all data in MAX
I can get I/O with "logos" protocol but is so slow (250-500ms/card) i have 6 cards...
I test with the config file .iak but i have a new problem when i save my configuration this message appear «  your configuration has been saved ….. reason possible : bank(s) offline or with read-only acces. » .
I wonder why i have a read-only access ????
I you have a solution, i take it...
Johan
(3,015 Views)
