How to access an opened application by giving commands to it?
I have to install an application(.exe file) using commands from labview instead of doing it manually. Is it possible?
(2,610 Views)
Use the "system exec" function in labview to run the installer from a command line.
msiexec should do the trick.  But it totally depends on the application you are installing.  Here is an example:
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/msiexec.mspx?mfr=true
You could compile your own labview VI into an EXE and build an installer for it.  Then you can call third party installers from there.
http://www.medicollector.com
(2,550 Views)
