How to access markers from traces in VNA through LabView Coading
Hi Folks!!
I am working on a project which includes the interfacing of the agilent pna x 5242 with LabView through GPIB port. Most of the helping material and codes are available but i am stuck on a marker accessing problem.
I successfully created the markers on the two different traces, each separate trace placed on seprate window but on same channel. I was able to place my desired markers on my desired X-axis frequecy point, as i required the corresponding Y-axis value.
but actual problem is that i am reading these markers from another VI. that VI is working perfectly but because of the fllow of the program i am able to read only the last generated trace markers and i was not able to read the markers of 1st trace.
picture 1 shows the traces and markers generation
picture 2 shows the marker placement
picture 3 shows the marker reading VI.
error which i VNA shows is "Uninterupted Query"
here are attached few parts of my codes ....
(2,588 Views)
