How to access the extra registers
if number of registers are 10,then i want to access 11,12,13th registers how can I access these registers using teststand........
(3,670 Views)
This question actually belongs in the TestStand forum, I think.  Are you trying to use LabVIEW to acess the TestStand API?
Kelly Bersch
Certified LabVIEW Developer
Kudos are always welcome
(3,632 Views)
No only in teststand simulation...
(3,609 Views)
one more issue :array index out of bound error code:17324 is produced in message popup and exception code:2 is returned in response of send frame. I tried to solve in many ways,it wont resolved give solution for its....
Thanks in Advance!!
(3,598 Views)
So what are you doing ?
There is NOTHING in your replies that tells us what you are doing.
What are you working with ? LabVIEW ? what version ? TestStand ? What version ?
What is your code doing? show us some code.
Where are "send frame", is it VISA ? CAN ? Ethernet ? Modbus ?
(3,591 Views)
