How to accumulate acquired data to array for plotting a real time XY graph
I have acquired current and voltage values of which I'd like to plot XY graph.
Problem is these are 1D waveform.
1. Please tell me how can I accumulate these value to array so I can have my XY plot.
2. Is there any other way  to plot real time XY graph of acquired values.
(I am using NI 9205 analog module. I can see real time waveforms i.e. current vs time and voltage vs time on my front panel.
I need current vs voltage of real time values.)
please help out.
thanks.
Message 1 of 8
(7,638 Views)
First use Index Array to get the two waveforms out.  Then use Get Waveform Components to get the Y components of each waveform.  Then use Build Array and wire that to your XY graph.
Message 2 of 8
(7,611 Views)
Actually, I have acquired 3 phase voltage and currents. I have to plot 'average current vs average voltage'. I have attached a test VI. can you please modify that to show me how to accumulate those changing values in an array so I can plot XY graph.
thank you.
Message 3 of 8
(7,566 Views)
Accepted by topic author kunal1261
Try something like this....
Notes:
  • If you simulate "as fast as possible", you should place a delay inside the loop.
  • Since the array grows forever, you will ultimately run out of memory.
  • SInce the x and y simulation is at the same frequency, all points will be on the same line.
Message 4 of 8
(7,545 Views)
Thank you for your suggestion. But I have to accumulate the acquired values in an array to plot the XY graph. Because  I won't just plot current vs voltage. I am also planning to calculate torque, speed and power values from current and voltage data and will be plotting torque vs speed, torque vs power plots.
So, please suggest me an alternative way where I can,
1) Accumulate the acquired values (via cDAQ)  in an array.
2) Plot real time XY graph.
3) flush that array whenever it seems overflow OR flush older values while recent values keep accumulating in the array.
  My previous comment has an attached VI. please help me out.
Kunal C.
Message 5 of 8
(7,509 Views)
The complex array contains all the acquired data, so you can calculate any derived values from it.
Message 6 of 8
(7,491 Views)
Hello all,
 I am using Labview 10. I need to plot a XY graph in the case both x and y values are changing. For example x=1, y= 2; x= 2, y=3; x=3, y=4;.......like that x and y values are changing continuosly. i tried to plot, but the XY graph screen shows the instantaneous values of x and y. But I need all the plot of all the x and y values.
For your referecne I attached my VI.
Kindly help me in this regard,
Thanks in advance.
Message 7 of 8
(7,263 Views)
Hi KUDOS!
Did you mange build that XY Graph to plot it in real time?
Message 8 of 8
(6,427 Views)
