How to accumulate data on a file for each run?
I have a program which start and stop controlled by external pulses. For each time it stops, the program reads the data. The data is three separate columns, say, X, Y and Z. How I can program so that for each run, the results (Data) should be accumulated on the same file? I mean, each time the pulse stop, it should read and accumulate in the same file successively.
Eg: Let's say a program named "Read". It has 'start' and 'stop' buttons.  When I click on 'stop', the program stops and gives the output X, Y and Z (three columns of data). Now, I want to replace manual 'start' and 'stop' with a pulse, from a pulse generator. So, it continuously 'start' and 'stop' many times. For each 'stop', it gives output X, Y and Z. How can I accumulate the outputs each time it stops, so that at the end I have the collective data of all the runs (all the start and stop)?
(2,677 Views)
There are many ways of accomplishing what you want to do. My recommendation would be to go through the online tutorials, and in particular check out the producer-consumer design pattern. It might be just the structure would are looking for.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,654 Views)
The general answer it to keep your data in a shift register which you build on each loop.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,630 Views)
I prefer to use the writing VI inside for loop.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(2,622 Views)
