When running my LabVIEW program using the data coming from 2 simulation sources, no problem occurs and data is correct.
When using the data coming from 2 DAQ-assistants (real data), an error occurs, telling the following:
"ERROR 50103 occured at DAQmx Read (Analog 1D Wfm NChan NSamp).vi, reason: The specified resource is reserved. The operation could not be completed as specified"
Does anyone know what exactly is wrong and how to solve this problem?
Nowhere I found a solution for this problem and I have been trying numerous things to change in the program, but the same problem keeps occuring.
Could anyone please help me?
I need to solve this to be able to perform tests for my graduation project.
Tha
nk you very much in advance,
Yours Sincerely,
Karel Rycek
