How to achieve faster directory creation?
Hi all,
if I create a directory with LabVIEW with New Directory.vi, it takes a few seconds (2-3) until it is really present in file system.
If a fast user works with the program I created, he could try to access the directory just before it has been created which produces an error.
Are there methods to speed directory creation and registration up?
Do I have to poll continously if the dir has been created?
(2,572 Views)
> error.
Is it that a call to ListDir fails to show the directory, or that the
Explorer doesn't update its window. I'd definitely expect the Explorer
to update at a slow rate so that it doesn't slow things down, but I'd
expect that a programmatic access to the folder/directory would succeed
immediately upon return. If you want the explorer view to updat
e more
quickly, you might need to look for an SDK call specific to that. I'm
pretty sure nothing in the LV palette will do that for you.
Greg McKaskle
(2,572 Views)
