10-21-2008 01:02 AM
10-23-2008 01:34 PM
Hello mjasso,
If you cannot buy NI hardware to interface with a camera, you have three options: firewire, GigE or USB cameras. From a datasheet I found on the web, the Sony dsc-s650 has a USB interface. The following knowledgebase article explains which USB cameras are supported: http://digital.ni.com/public.nsf/allkb/89E33B77CFE244E986256F8E004E0F13 . You will need the NI-IMAQ for USB driver if the camera has a DirectShow filter. You will probably have to contact Sony to verify this information.
Please refer to the following webpage to see the requirements for the IMAQ for USB driver: http://sine.ni.com/devzone/cda/epd/p/id/5030 . I hope this helps.
