How to activate another worksheet in excel file and write data into it
I am writing an automation program to collect test data and write the data to an excel file.
The excel file has several worksheets and now I can only write data to one sheet. Can anyone please let me know how to activate another worksheet and write data into it? Thank you very much.
(4,863 Views)
You can do a search in the Example Finder for more Excel VIs.
They will give you a clearer idea of how to go about doing things in the way you need.
- Partha ( CLD until Oct 2027 🙂 )
(4,855 Views)
You need to access the "Sheets" property of the workbook object, and then use the "Item" method to select a specific worksheet. MSDN contains documentation on the Excel automation objects.
(4,834 Views)
