How to add DataSocket Server in exe file?
I am using DataSocket in my vi and want to generate exe file. Does anyone know how to embed DataSocket Server in the exe file?
(3,093 Views)
Hi Alan
You have to build an installer. In the Application Builder there's a tab "Installer Settings". Select "create installer" and click the "Advanced" button. A new window appears, where you can select things to include. Select "Datasocket Support".
If you then build the application, a installation routine (.msi) is create. This you can install on a target machine and the datasocket function should work.
Hope this helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,089 Views)
