How to add VI to library again?
I am currently using labview 8.2. Everything was working fine just before I uploaded a backup program for WindowsXP. I now get an error in NI_AALBase.lvlib:Vector x A..vi and complex vector x A.vi.  how can I retreive the library. The error says "This VI is connected with a library that does not include the VI. The VI might have been deleted from the library. Add the VI to the library again or select File»Disconnect from Library."
I tried reloading Labview 8.2 and still get the same error.
Please see the image of the error below.
(4,976 Views)
Hi Muke,
what are the locations of the 'Vector x A.vi' and 'complex vector x A.vi'? If they are not in the vi.lib (or one of it's subfolders) they are moved (as a backup procedure or something).
In that case do not connect them to the 'NI_AALBase.lvlib' in the vi.lib folder, just disconnect them inside the VI
In the other case, the 'NI_AALBase.lvlib' has changed. This is very strange, what you should do is a repair of LV because maybe other things have changed!
Ton
My LabVIEW Ideas
(4,954 Views)
