How to add a background image behind the graph plot area
Hi all,
I would like to know if there is a way to add a background image (*.png)
behind the graph plot area?
What I would like to accomplish is that during an acquisition measurement you can see
if the result values are out of specs or not.
I have found this link:
https://www.ni.com/docs/en-US/bundle/labview/page/customizing-graphs-and-charts.html
But it’s way to difficult for me, I don’t understand it, is there a more simpler way to just
add a picture (*.png) behind the graph plot area?
I want something like this, were the blue area is right zone
everything outside this erea is wrong,
(4,569 Views)
Instead of adding an image (which gets messed up as soon as your graph scales change) plot the upper and lower limits as data for Plots 3&4.  You can set Plot 3 to fill to Plot 4 and this way it will scale with the rest of your data also.
(4,544 Views)
Accepted by topic author AudioDandy
It's not visually quite as nice, but it's more robust and adapts better to UI changes.
(4,540 Views)
Thank you Intaris for your fast reply,
Looks a fine solution for me, I'm going to try it!
Maarten
(4,530 Views)
