How to add a dial control to a vertical progress bar
I need to put a dial control on the bottom of a vertical progress bar and have the dial control the value the progress bar is showing. I can't find the option to add a dial to the bar. When I create a dial and try to connect it the data type is not the same so it's not connecting and I can't seem to find a way to change the data type of the progress bar to be the same as the dial which is set as a DBL.
(2,447 Views)
Accepted by topic author benm92
You could create two controls and use an event structure for the value change of either updates the other control.
(2,430 Views)
All you need is a single control with one terminal and no code at all.
Just customize your progress bar in the control editor and replace the digital display with a dial.
Have a look at this example (but read the entire thread and also these instructions). Works for controls or indicators, of course.
(2,359 Views)
