How to add a enum or a boolean to a specific cell of a table control?
I want to add enum or a boolean control to some specific cell programmatically .
do we have some customised control,so that we can select from a enum option except the string controls in the cells of the table control.
I would also like to have a radio button control except the string control in a table.....
Certified Labview Associate Developer(CLAD)
Don't Forget to Rate the answers.!!! You can do it in few seconds
Message 1 of 18
(7,303 Views)
yes you can stick a boolean or enum into an array (of that type). use the insert array function
Message 2 of 18
(7,279 Views)
Am I mistaken or do you want to take a table, which is an array of string cells, and insert a Boolean or Enum cell in amongst the string cells?
I doubt if it is possible, but it would be a wonderous thing if it was.
McSynth
Message 3 of 18
(7,274 Views)
arrays have to have the same data type for each element
Message 4 of 18
(7,270 Views)
Vivi,
My point exactly.  So why would you say that's it's possible to add a Boolean or Enum into a table control?
McSynth
Message 5 of 18
(7,265 Views)
oh whoops i thought he was asking about arrays.
i am sorry for the mixup.
Message 6 of 18
(7,263 Views)
It is not possilbe to put anything other than a string in a table.
See this thread for a away to use an array of clusters to get a similar look.
http://forums.ni.com/ni/board/message?board.id=170&message.id=149374#M149374
Ben
Message 7 of 18
(7,250 Views)
Ben,
Thanks for the info.
but the visibility is not so good,
Can we do the same with the help of using ActiveX controls from other tools..?
DK
Message 8 of 18
(7,233 Views)
Other thing is how we can add a scroll bar to a cluster..?
Message 9 of 18
(7,230 Views)
You can not do that as far as I know.
Message 10 of 18
(7,220 Views)
