How to add a graph to a pwm signal
I'd like to see the output signal that I generate with a compact daq and a ni9474 card.
My VI is a simple pwm generation wit daqmx (see attached file)
Thank you.
(3,784 Views)
Could you please convert it to LV12?
(3,768 Views)
(3,764 Views)
Does anybody can help me?
Thank you.
(3,744 Views)
You can't see the counter output exactly, but you can wire it back into another Analog input and read it.
Or you can simulate a square wave at the frequency and duty cycle you specify then show that.  Drop the Square Waveform function, generate a wave using the Frequency and Duty Cycle you specified, then graph the output.  Reading the wave back on an analog might be a better solution if you really don't trust what it is generating.
(3,718 Views)
