How to add all the previous values of an array till the index value
     I don't think both will work out since my need is different. If I enter the 7th year, the algorithm should calculate 1st year's cost with the respective values, then the 2nd year's value alone and add that with the first one and so on. Please give me a solution for that.
Message 11 of 14
(707 Views)
Hi niks,
You already got two possible solutions. How much more do you need?
Message 12 of 14
(704 Views)
Then use a loop!
Please don't describe a problem, get solutions, then say they won't work because there is more to your problem that  you didn't bother to describe up until now.
Message 13 of 14
(698 Views)
Thanks. I made some more changes and got the solution. Thanks for all your suggestions and helps.
Message 14 of 14
(679 Views)
