How to add an data in an existing file
Hi, I have the following problem:
I  am implementing a data logger using the RS232 port and Labview, I have not problems with data capture my problem occurs when I store the data in a file, I need that every time the data is registered this data must be updated in the file
How  do I can do this?
(2,539 Views)
Use the "Set File Position" function to set the file pointer at the end of the file which is where the next write will write the data.
Omar
(2,536 Views)
If the data file is some type of delimited text (tab-delimeted text, csv, etc) you can just use the Write to Spreadsheet File.
Just make sure you wire True to "Append to File?"
Cory K
(2,531 Views)
