How to add delay between 'write' and 'read'
I am using scope and LabVIEW 7.1
Everytime after I 'write' some commands to scope, I'd like to delay for a while before I use 'read' to get data from scope. How to do that? I always got trouble becuase the 'write' is not finished yet and 'read' has already started.
TBird
(3,599 Views)
How are you communicating with your device? Do the write and read VIs have an input for connecting the reference for the device you're talking to? If so, simply take the output from the write VI (reference and error) and wire those into the read VI. As a basic principal of LV and of dataflow programming, this will cause the read VI to run only after the write VI has completed running. If this doesn't help you, you can artificially create a wait period by using a sequence structure and having a frame with the Wait VI between the write frame and the read frame, but this method is less recommended. If this didn't help you, I suggest you post your code, or at least a picture of this section of the code.
___________________
Try to take over the world!
(3,589 Views)
Hello Thunderbird,
it seems you don't use a proper "data flow"...
When you write/read data to/from scope the used vi's should have an error cluster input/output. If you connect those then the read operation cannot occure before the write command operation. To include a delay between them you can use a sequence with a "Wait (ms)" where you tunnel through the error cluster. Or write your own subvi which includes a "wait (ms)" and the error cluster connections, then you don't need a sequence at all.
Hope this helps,
(3,588 Views)
