How to add the libXML library to labVEW environment
If there any step-up step procedure available for how to add the libXML library to the LabVIEW environment.
Message 1 of 8
(4,013 Views)
Do you mean this LibXML? http://xmlsoft.org/
If so, it looks like a standard C library, so look for guides relating to the Call Library Function Node (CLFN) and calling C language functions.
In terms of "adding it", yoou need to either specify a path, or place the DLL at a location on the search path.
You might find this thread useful: libXML Examples
GCentral
Message 2 of 8
(3,968 Views)
Yes, Correct LibXML only.
https://forums.ni.com/t5/Example-Programs/Libxml2-Parsing-XML-in-LabVIEW-is-too-slow-or-is-it/ta-p/3...
From the above link, I had to download the Libxml setup and some of the examples.
1. I have installed the "libxml2-1.0.0.2.vip" in my system.
2.LibXMLUpdate(2.1) in this folder I tried to run the Main.VI but I get an error like " Not executable VI".
 Do I have to do any setup to solve this issue?.
The above link which is the folder is required to use the LibXML
Message 3 of 8
(3,910 Views)
Not executable VIs (broken run arrow?) will usually tell you what the problem is.
Can you open the error list (click on the broken run arrow, or Ctrl+L, or View >> Error List) and tell me/us what you see?
GCentral
Message 4 of 8
(3,907 Views)
FYI.
Message 5 of 8
(3,903 Views)
Ok, so from that image I can see that the errors occur in the top two VIs (the ones with the errors are always at the top, and have a red X mark).
You need to read those errors (the ones with X marks) and fix them, then you should be able to run Main.vi.
At the moment, main cannot run because it needs those subVIs to work.
GCentral
Message 6 of 8
(3,894 Views)
It seems the LibXML DLL issue. I want to know that how I will configure the Libxml.
 is there any procedure to configure the LibXMl to avoid these errors?.
Message 7 of 8
(3,891 Views)
I have fix the Error in the error list which is indicate the X mark. Now am able to run my main.vi but in the "selected node sub.vi" received length as a 0 output.
Code files attached.
Message 8 of 8
(3,713 Views)
