How to add time to string timestamp
I have a problem with adding time to string timestamp that is shown on image below.
What I need is to add some time eg. 1 hour, but if that change happens between 23:00 and 00:00 I need to change date to.
Wanted results for example:
14:53, 22.4.2015. --> 15:53, 22.4.2015.
23:33, 22.4.2015. --> 00:33, 23.4.2015.
Please help
(7,722 Views)
Use actual timestamps instead of strings. Explain why you think that strings should be used.
(7,697 Views)
Accepted by topic author SuperbrainBug
Use the Get Date/Time in Seconds function to get the time, use this form to add and subtract time (to add an hour, simply add 60*60 seconds), and use the Time-Stamp input to the Format Date/Time function when you want a String implementation.
Bob Schor
(7,694 Views)
1 - use timestamps instead.
2 - if you are stuck with strings because they are coming from elsewhere, convert back into a timestamp to do the math
(7,689 Views)
Here are two ways.  One adds a time value from string, the other adds a time value from a double.
(7,680 Views)
Thank you for help. This was exactly what I needed.
Bye
(7,638 Views)
Just because you have end up with strings does not mean you can't start with the correct data type.
(7,623 Views)
