How to add two channels to a graph and change the desired number of channels to be monitored
Hi there,
I was wondering how to take two specific data type i.e. "Sine" and "Cosine" and have them displayed on a graph one in x and one in y, and also how to use shift registers so the graph appears as the data is measured.
Cheers.
(2,425 Views)
To have the data be plotted as they appear, use a Chart, not a Graph.  When you put the Chart on the Front Panel, right-click it and examine the Help, which should tell you how to plot two curves.  Alternatively, learn LabVIEW.
(2,417 Views)
