How to add visa usb support to the application builder?
Is it possible to add VISA USB drivers to the application installer?
www.xinstruments.com - Custom Software for Industrial Automation
www.hdrconverter.com - Picture processing made easy
(3,037 Views)
I'm afraid you can't do that. The LabVIEW 7.0 application builder only supports adding the VISA serial port driver to the application builder installer.
You will have to install the VISA support for USB separately by using the VISA 3.0 runtime installer.
Rolf Kalbermatter  My Blog
(3,037 Views)
Hello Alexander,
Please refer to the following Knowledgebase for instructions on how to package other installers with the installer for a LabVIEW application
http://digital.ni.com/public.nsf/websearch/A4B55CA4CAE930D1C1256C09007928E6?OpenDocument
Jyoti F.
(3,037 Views)
Thank you Jyoti and Rolf for the tips, it's very useful. By the way, do you know if it is possible to separate usb driver (or any other component) from VISA installer? And do you know if it's possible to configure the setup process? I mean following thing: when you enter VISA setup it suggest to install all of it's components. And if you need only usb support you should deselect all other unnecessary drivers. So the question is: can i change default VISA installer settings?
(3,037 Views)
