How to adjust the sampling rate during measuring with the PDA
Hello everybody,
Is there a possiblilty to show the current sampling rate on the screen of the PDA, and can I use this value to integrate it into my calculations. At the moment I just know how to set the sampling rate for measurments with the PDA during I program the application.
Every help appreciated
Message 1 of 8
(8,094 Views)
Hello!
Are you programming with LabVIEW?
Which driver are you using? DAQmx Base?
How do you set your sample rate im program? With a control? It is not possible to wire directly your samplling rate control to your calculation?
Regards
Ken
Message 2 of 8
(8,072 Views)
Thank you for your reply
I am programming with LabView PDA-Modul
As Driver for my NI CF-6004 I am using the DAQmx Base 2.0.
By using the NI-DAQmx Base Task Configuration Utility I creat DAQmx Base Tasks.
This Tasks are setting the sampling rate.
In the PDA Modul there are only the DAQmx Read, Write, Start, Stop and the Task Config/Ctrl VIs available.
Do you mean with control another DAQmx data acquisition VI?
Regards
FReich
Message 3 of 8
(8,058 Views)
Hey
I'm not sure about Daqmx Base 2.0 but with 1.0 I had to modify the Read VI to pull the sample rate out.  It's in there somewhere.  If you like I could dig into my VI's and find it.  Hopefully somebody has a better solution.
Eric
Message 4 of 8
(8,042 Views)
Hey Eric,
thank you for your reply. It could be of great help, if you find this modified Read VI and post it here.
Cos at the moment I dont have any clue how to deal with that problem.
Message 5 of 8
(8,034 Views)
I was wrong about the Daqmx read it was actually DAQmxBase Start Task ESeries that was modified.
Hope this helps
Eric
Message 6 of 8
(8,025 Views)
Thank you,
I think thats the way to the solution. I will try to go this way.
The problem is just that the read VI in my LabView version is quite different. Have a look at the picture.
It uses libraries to save the sampling rate etc.
I think maybe there is a possiblity to access the library with another VI, or maybe I just use your VI if its possible.
At the LapView 8.0 PDA Modul the Sampling rate is set by the DAQmx Base Configuration Utility which put this info into a library file,
it seems that in older version it has been done in the VI itself which means there has been no DAQmx Base Configuration Utility.
Am I right about that?
Message 7 of 8
(7,981 Views)
What does your start Daqmx Task look like.  You should be able to find the rate info in there.
PDA Modual 7 does use the Task Configuration Utility.
Eric
Message 8 of 8
(7,916 Views)
