How to adjust the scale of a chart between 2digits?
hi,
I made my charts for different processes that I wanted,I just need to adjust the scale of a chart between 2digits now,I need a method which is possible to be applied for both X,Y.
thx,
(2,953 Views)
I don't understand what you want. Is it just to set the min and max of the scales?
(2,946 Views)
forexample:
for my Y:
 I need it to be set from -1000 to 1000 (as it is my current)
for my X:
 I want it to be set from 0 to 80
and also I want my X,to be work as seconds(from second 0,till 80seconds after),so I need it to follow the period of 1seconds between it's scales,
thx,
(2,943 Views)
Programatically, you use the Xscale (or YScale) Range.Min and Range.Max. Be sur to turn off autoscaling.
I would suggest you look at example called Real Time Chart to learn how to set the Offset and Multiplier properties to match acquisition time.
(2,930 Views)
in my block diagram,in scales tab,I don't click on auto scale,but still it uses 2digits that it likes,not mine,and also for time(my X),still it doesn't work,
(2,921 Views)
