Hi, I have to draw a bar plot and when I wire values to the chart for some reason they are almost 1 inch think for each number. I was wondering how to adjust the width such taht it is something more like 2 mm per entry?
What you seem to be running into is the autoscale on the X-scale. Right click on the X scale and turn off autoscaling. You will then have to manually set the scale to get the width that you want.
