How to analysis waveforms from NI 5105(NI SCOPE)
Hi all,
    I am trying to anaysis waveforms from NI 5105(NI scope),as a newer in labview,meet some difficults. I want to caculate  delay time of different channels output from PSU.  Detailed information: Channel 5 as trigger source, channel 0 as one channel of PSU output channel, channel 1,2,3,4 as the same. Channel 5 will input +48v from DC source. I have used property node to anaysis delay time,but only can caculate two channel between channel 0 with channel 5 as a example,can't at the same time caculate channel 1 or 2,3,4 with channel 5,it executes efficiency too long time. so is there another method to anaysis delay time.
   (delay time when channel0 +48v output catch 48*90%V this point compare with DC source +48v input catch
90% this point ,caculate its delay time through time subtract each other.
Note: labview 8.6.1
Thanks .
-DoubleminW
(2,558 Views)
Add picture of  5 channels waveforms
(2,554 Views)
