How to anchor a label to object(s) on Block Diagram?
Is there a way to anchor a label on the Block Diagram to an object or group of objects...so that if you move it/them...the label moves with them?
Thanks in advance,
cayenne
(3,223 Views)
What type of object?
I don't know about groups, but you could make the label visible on just about any object.  Use that and it will stay with that particular object.
(3,222 Views)
I typically re-use structure labels (FOR loops, case structure, while loop, etc.) for documentation (Right-click... show label...modify label). These are anchored to the structure and stay with the structure (and anything in them). 😉
In LabVIEW 2012, we also have subdiagram labels.
(3,217 Views)
OK, thank you, I"ll likely try that.
I was referring to the "Free Label" object under the Structures->Decorations section of the palette...thinking maybe you could associate this with some code...also, I'm guessing there isn't a good wayt to 'group' parts of code on the block diagram, like you can on the front panel, is there?  Those options appear greyed out when I select a number of objects on the block diagram and look there.
I was wanting to us that to make sure when I was dragging sections of code around that I want to keep together, it would always travel around the screen as one....much like the front panel. I was hoping to include the Free Label that way too...
Am I missing something, or is this functionality just not available? If it isn't available...why are the group/ungroup options (even while greyed out) shown on the menu system of the block diagram section?
Thanx,
cayenne
(3,176 Views)
Your situation seem to be the typical case where you should be creating a subVI and the associated documentation for this portion of code.
As soon as you see that you need to move/copy a part of your code from time to time it is recommended to create a subVI.
Baptiste
(3,160 Views)
