How to append Get Date/Time vi into a the start of a 2D array
Does anyone know a way of appending a date and time string into a numeric double. I have attached my code. Perhaps i should append after the numeric/string conversion?
(3,213 Views)
The elements of an array must be all of the same type, so you can't do that.
To have different types in a structure you can use clusters instead.
Paulo
(3,205 Views)
You can actually do this without clusters in one of two ways:
1) LV stores time as the number of seconds that have passed since 1/1/1904 00:00:00, so you can store this number. To do this, use the Get Date\Time VI from the Time&Dialog palette, and convert the timestamp to a DBL (using To DBL from the Numeric>>Conversion palette). This isn't readable because the number is currently 3.something * 10e9 but LV can turn it back into time. I suggest using this method because you can easily manipulate this time format in LabVIEW (compare, add, subtract and so on).
2) The other way would be to create a number to represent your data (like 10022004). This has several problems and I think using clusters is preferable.
___________________
Try to take over the world!
(3,196 Views)
Also, If you use the Date\Time to seconds VI you get a cluster of all the values. Use unbundle on that cluster to get Month, Year, Day and so on.
___________________
(3,185 Views)
"Perhaps i should append after the numeric/string conversion"
Since it looks like you're going with a table and need a 2D array of strings anyway: Yes.
Fading out. " ... J. Arthur Rank on gong."
(3,181 Views)
Hi Donald.
I quite simply didn't notice that part of the code (and the question).
This seems to be a real issue,
___________________
(3,168 Views)
Spot on Donald. Many thanks.
(3,162 Views)
