How to append and sort 2D array?
Hi Mike
This one is little hard understanding for me, Could you please explain some details if you have time? especially the part I put into the attached picture. what is the name of "R /IQ", I can't find it, and what is 2 and 9 stand for?
Thank you Mike!
Jing
Message 11 of 19
(2,107 Views)
Ok I found the block R/IQ it is called" quotient & Remainder"
Message 12 of 19
(2,100 Views)
Hi Mike
I already fully understand, Thank you. that works well
Thank you so much!
Jing
Message 13 of 19
(2,096 Views)
Hi jing,
nice to hear it. Smiley Happy
Mike
Message 14 of 19
(2,089 Views)
Hello Mike
I need to ask you a stupid question I am wondering for a quite while,
sometimes you create some blocks, and I can not find them from function panel directly, I want to know how can u create them. like in the attached picture.
Thank you for  your answering!
Jing
Message 15 of 19
(2,073 Views)
Hi jing,
it is a shift register. If you have a loop, you can right click on this loop and select "create shift register". Smiley Wink
You can store data in it so that you can use the data you wrote the last iteration in it, in the current iteration.
Mike
Message Edited by MikeS81 on 06-04-2008 01:06 PM
Message 16 of 19
(2,071 Views)
Hi Mike!
How to create these two look at attached picture and what are these for?
Jing
Message 17 of 19
(2,066 Views)
Hi jing,
this are array constant. You can create them in the block diagram. You find them in the array section, on the bottom left side. In this empty array constant you can insert your data type. Take for example a dbl constant and insert it into the empty array constant. You can use them to initalite the shift register. In your picture one is to initialize the shift register with an empty dbl array, and the other is to specify which files you want to open inside the for loop.
Mike
Message 18 of 19
(2,058 Views)
Hi Mike
Thank you very much for answering my silly questions patiently!
I am really lucky to know you!
Jing
Message 19 of 19
(2,056 Views)
