How to append new data into older csv file.
Hello all,
I need small help. Please help me.
How to append new data into older csv file with File I/O functions.
As per below image,
  1. First time I got 3 signals data (Signal-1 to Signal-3) & I stored into *.csv file.
  2. Next time I got 3 signals data(Signal-4 to Signal-6). So, I want to add these signals data to same csv file.
  3. Next time I got other 3 signals data(Signal-7 to Signal-9). So, here again I want to save these signals data to same file.
This signals data depends on user request (Signal count is not fixed).
Please give me any idea about this.
Munna
Message 1 of 12
(7,589 Views)
As far I know you cannot append data to the columns unless you read the complete data and append it in LabVIEW and write everything again.
Message 2 of 12
(7,573 Views)
I thought of reading same file again line by line & adding new data to each line & writing into same file.
But,sometimes offset length is missing to inset new data into old positions. I’m not getting properly.
Munna
Message 3 of 12
(7,564 Views)
If you have the data column wise then just read the data and build it along with the new data (This will be a problem when the file size increases) and write it again. This case you don't have to set the file size since you are re-writing the whole data.
Message 4 of 12
(7,552 Views)
I have comma delimited values.
Here, the problem is, I want to do read & write (old+ new data) into same file.
Suppose, reading 100 lines, replace those 100 with new data & so on.
Munna
Message 5 of 12
(7,543 Views)
In order to append columns, you need to read in the entire file. Once you have a 2D array with the Read From Spreadsheet File, a simple array manipulation will get your extra columns and then you just write the file back with the same name.
Message 6 of 12
(7,532 Views)
Dear Dennis_Knustson,
Thanks for your reply.
Actually I have large set of data file (file size is huge). So, I’m unable to read entire file at once ( because of memory issues).
Munna
Message 7 of 12
(7,523 Views)
Then you should rethink the file storage scheme that you are using. Look at the tdms functions.
Message 8 of 12
(7,520 Views)
I thought of changing csv to tdms.
But, here also I’m facing other issue.
Sometimes, I need to write string data between some signals (like, Signal data + some conditions information etc.).
Now, I’m planning to use report generation toolkit. But execution time will increase.
Is there is any other ways?
Munna
Message 9 of 12
(7,507 Views)
If the data size is large I would reommend you to go for *.bin files and then convert it to Excel when it is needed. Binary files can hold the different data types as you wish.
Message 10 of 12
(7,497 Views)
